Free shipping on orders over €55!
Overview Features Reviews
ELEMNT BOLT GPS Bike Computer Bundle
€329.99
More Views
Cycling Bundle with an ELEMNT BOLT Bike Computer, TICKR Heart Rate Monitor, RPM Speed Sensor, and RPM Cadence Sensor
SKU# WFCC3B
€329.99
  • Free Shipping On Orders Over €54.99
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Reviews
Product Overview
Get everything you need to boost your cycling performance all at once! The ELEMNT BOLT features a patent pending design that integrates the bike computer and mount, resulting in a CFD tested, highly aerodynamic system built to be on the front of your bicycle. Not to mention, it's super easy to set-up and customize with the free companion app and features dual-band technology, wireless connection & uploads, pre-loaded global maps and routes, and so much more. The TICKR heart rate monitor, RPM Speed sensor and RPM Cadence sensor pair seamlessly with the ELEMNT, so that you can get live and accurate performance metrics.
BONUS! When you register your ELEMNT BOLT in the Companion app, you'll receive these awesome offers from our partners:
The ELEMNT BOLT is the most integrated GPS bike computer on the market with a full list of compatible hardware and smartphone apps.
ELEMNT BOLT FEATURES
Discover all the nitty gritty details about the BOLT GPS bike computer
TICKR FEATURES
Discover all the nitty gritty details about the TICKR heart rate monitor
RPM SPEED FEATURES
Discover all the nitty gritty details about the RPM speed sensor
RPM CADENCE FEATURES
Discover all the nitty gritty details about the RPM cadence sensor
Includes Mounts for ELEMNT BOLT bike computer and RPM Sensors
ELEMNT BOLT Two sturdy and secure mount options - an integrated out-front mount and stem mount. RPM Cadence comes with a crank and shoe mount. RPM speed comes with a hub mount.
Click here for ELEMNT BOLT instructions
Specs
ELEMNT BOLT Specs
Physical Dimensions: 2.9"" x 1.8"" x 0.87"" (74.6mm x 47.3mm x 22.1mm)
Display Size: 2.2"" (56mm)
Weight: 2.2 oz
Battery: USB rechargeable
Battery Life: 15 hours
Waterproof Rating: IPX7 (waterproof up to 5 ft)
Supported Satellites: GPS, GLONASS, BEIDOU Galileo, and QZSS
Operating Temperature: -4°F to 122°F / -20°C to 50°C
TICKR Specs
Physical Dimensions (LxWxH): 2.75" x .5" x 1.5"
Weight: 8.5 grams (without strap)
Battery: CR2032
Battery Life: Up to 12 months
Sweatproof: Yes (hand washable strap)
Water Rating: IPX7 (waterproof up to 5 ft)
Strap Length: Adjustable from 24" to 48" (stretched)
RPM Cadence Specs
Physical Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams
Battery: CR2032
Wireless Signal Strength: Up to 10 feet
ELEMNT BOLT GPS Bike Computer Bundle is rated 4.6 out of 5 by 43.
Rated 4 out of 5 by from Easy to service up and use I bought the Bolt bundle before a trip to the Pyrenees. I used Strava, which tended to burn my phone battery, and felt having a bike computer, instead of my phone, would not just save battery, but also provide more robust data. Generally the Bolt worked great. If I had a complaint it would be that the Elemnet Bolt didn’t always download my data to Strava post ride ... a couple of times I had to push my ride data from the element app to the Strava app. Aside from that, the Bolt was a success and a good upgrade from my Cateye. It’s super easy to set up (and I’m a Luddite), easy to use, the readout is clear and the features - given the price - are better than those of Garmin. For a relatively serious cyclist, I’d recommend this product.
Date published: 2017-09-22
Rated 5 out of 5 by from All I Will Ever Need I did quite a bit of research before buying this unit. I determined that the features that I wanted could be found for less money with the Elemnt Bolt. Upon opening the box and charging the device it worked entirely as described. The fact that I can rearrange the location of the "screens" is huge. Scrolling through pages to dial in on other details in the middle of the ride is very cool. The HRM feature works like a charm. Friends and family members have some flavor of Garmin. This doesn't do everything that theirs do - but mine cost several hundred dollars less. As I said in the title, it is all I'll ever need. It's all most riders will ever need. Altimeter, check. HRM, check. Speed, cadence, time, laps, routes, sync with Strava - all check. I recommend it without reservation unless you are super dialed into every detail of your ride and have no other interests in your life except to analyze your ride data.
Date published: 2017-09-18
Rated 5 out of 5 by from Super easy to use! Not much or a tech guy and resisted using a computer even though I am a hard-core enthusiast but the BOLT is so simple to set up and it interfaces seamlessly with devices and apps that it made the entire experience effortless. Ive already noticed gains in my cycling from using the BOLT.
Date published: 2017-09-14
Rated 4 out of 5 by from Best computer yet + Love it, great app, best HR and metrics capture and report via app or Strava - have to remove cadence battery after riding or it dies
Date published: 2017-09-08
Rated 5 out of 5 by from User friendly I moved over the the bolt from a Garmin. The Bolt is just so easy to use, all configuring is done from your smart phone and automatically sent to the bolt. Whilst riding the different screens are easily navigated and the zoom in/out feature makes its easy to see lots or little data at the touch of a button
Date published: 2017-09-07
Rated 5 out of 5 by from Love this much better than my Garmin I have had my unit for 3 weeks now and I am absolutely loving it. Everything about it is awesome, the size, the features the functionality.
Date published: 2017-09-06
Rated 1 out of 5 by from Great features and easy to use, but the quality? Ordered the Elemnt BOLT bundle as a gift for wife. Functionalities and easy to use are plus (you can set up the page via your phone app and once it links to the strava and/or ride with GPS, you can have all your activities/maps/routs sync into your GPS unit (feedback to Strava to share with friends); you do need to subscribe a premium service for turn by turn instructions under "ride with GPS"); however, the quality of the product is an issue for me and the customer support also needs lot improvements. Please Note, on my first two times of uses, My wife and I thought this is a great product and Garmin is facing a tough competition. What I am going to explain my personal experience down below, it could be just happened to me as an one time incident, I believe that this should not happen frequently and effect every buyer. The unit itself was under proper care, not use under raining condition nor drop on floor. On my wife third use, the GPS monitor start discoloring and fading images. I purchased on Aug 15th, the malfunction started on Aug 27th. Contact the customer support on 28th, took me 8 days to get a return call tag (a return label) to send the product back. They said, once they received the return unit, they will send the new one to me. Hate to deal with this kind of customer service, ineffective and not responsive. Over the labor day weekend, we decided to give one more try, the screen is completely dead and we were not even able to use it at all. May be I got a lemon unit, but my current experience make me re-think if I want to get Wahoo for my next upgrade, wait for a better and less troublesome future Wahoo product, or just stay with Garmin.
Date published: 2017-09-05
Rated 5 out of 5 by from Display, setup Big numbers of display for cyclist with a worse eyesight. Direct setup from the phone.
Date published: 2017-09-04
  • y_2017, m_9, d_24, h_2
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.3
  • cp_1, bvpage1
  • co_hasreviews, tv_1, tr_42
  • loc_en_US, sid_WFCC3B, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 58.57ms
Product Overview
TICKR FEATURES
RPM SPEED FEATURES
For more info, see Faq
Specs
ELEMNT BOLT Specs
Weight: 2.2 oz
TICKR Specs
Battery: CR2032
RPM Cadence Specs
Weight: 7 grams
Battery: CR2032
Reviews
