• Standard Shipping No Longer Available for Orders to Arrive Before Christmas
TRACKR SPEED
€39.99
The Wahoo TRACKR SPEED sensor is the sleek, magnet-less solution for capturing cycling speed data. It easily mounts to your bike's front wheel hub, and the Bluetooth Smart and ANT+ dual band technology allows you to connect to and display data on both smartphones and bike computers. Tracking speed data has never been this easy.
TRACKR SPEED
TRACKR Speed
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 200 hours of use.
Universal Fit
TRACKR SPEED will fit with most hub sizes.
Dual Band Technology
Both ANT+ and Bluetooth Smart allow for a wireless connection to both smartphones and bike computers.
Visible Connection
Two LED lights show the sensor's device connection (blue) and speed detection (red).
What’s Included
  • TRACKR SPEED Sensor and Mount
  • CR 2032 Battery (installed)
  • Quick Start Guide
Tech Specs
  • Part Number: WFTRACKRSPD1
  • Physical Dimensions:
    • W: 3.5cm x H: 3.2cm x D: 1.8cm
    • W: 1.4in x H: 1.3in x D: 0.7in
  • Weight: 13 grams (0.5 oz)
  • Battery: CR2032
  • Battery Life: Up to 200 hours
  • Water Rating: IPX7 (submersion up to 1 meter for 30 minutes)
  • Maximum Hub Diameter: 40mm
  • Note: Speed Sensor is NOT compatible with spin bikes
