Free shipping on orders over $55!
Wahoo RPM Speed and Cadence Sensors Bundle
Wireless Speed and Cadence Cycling Sensors
More Views
SKU# WFRPMC
€69.99
Shop with 100% confidence
fast international shipping / awesome customer service / no hassle returns within 30 days / limited warranty / get help from a pro (a cycling/running/fitness-loving wahooligan!)
Wahoo RPM Speed and Cadence Sensors Bundle Overview
All you need for cycling data, all together at once! The Wahoo RPM Speed and Cadence sensors are both a sleek, wireless, and magnet-less solution. Each mounts easily to your bike and the Bluetooth Smart and ANT+ duel band technology allows you to connect and display data on both smartphone and bike computers.
RPM Speed Features
Discover all the nitty gritty details about the RPM speed sensor
RPM Cadence Features
Discover all the nitty gritty details about the RPM cadence sensor
Supported Devices
iPhone
iPhone 4S and newer
Android
Click here for compatible devices
iPad
iPad (3rd gen and newer), iPad Mini, iPad Air
iPod
iPod Touch (5th gen)
Specs
For both RPM Cadence and RPM Speed
Dimensions (LxWxH): 1.25" x.75" x 1"
Weight: 7 grams (without mount)
Battery: CR2032
Battery Life: Up to 12 months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength: Up to 10 feet
In the Box
For RPM Cadence
RPM Cadence sensor CR 2032 Battery (installed)
Rubber Mounting Option
Zipties
Shoe Mount Option
3M double sided tape
Quick Start Guide
Important Product Info Guide
For RPM Speed
RPM Speed sensor CR 2032 Battery (installed)
Hub Mounting Option
Quick Start Guide
Product Instructions
Click here for RPM Cadence instructions
Click here for RPM Speed Instructions
Reviews
Wahoo RPM Speed and Cadence Sensors Bundle is rated 4.4 out of 5 by 76.
Rated 4 out of 5 by from Great deal Both sensors are easy to install and syncronize with the wahoo element or app. Two things you have to be care of 1. Speed sensor fits a little large on the free wheel hub 2. Speed sensor battery came installed and already dead. I have to buy a new one without any use.
Date published: 2017-05-10
Rated 5 out of 5 by from just does what needs to be done Bought as replacement for Blue SC, is a lot easier to install. Works great.
Date published: 2017-04-29
Rated 4 out of 5 by from Why only Apple.. Has been happy with the sensors and ease it is to install, but a huge bummer that you can't use autopause on it when you are using Android, but being told it works with Apple. Hopefully will quick get this upgraded.
Date published: 2017-04-19
Rated 5 out of 5 by from Easy as pie! It's so easy to install and they work like a dream. I bought them when I purchased the new element bolt and I've been very happy ever since.
Date published: 2017-04-15
Rated 5 out of 5 by from Works great I bought this bundle after purchasing and returning several other products for speed and cadence. All of those products had issues syncing up with my phone. Not the Wahoo parts. They worked PERFECT. I downloaded the wahoo app on my Note 3 and put the sensors in the bike. Took about 5 minutes total time. Spun the crank on the bike, sensors woke up and phone connected. There was an update for the cadence sensor which the wahoo app automatically downloaded and installed. Next over to strava. Once again no problem. Strava connected to the sensors and worked perfect. These wahoo sensors are wonderful, simple, easy to setup and work!! No need to fool sound with the sensors from other companies. Just get these and get data. Also install simple and easy. Speed is in a rubber mount and simply loops over the hub. Cadence is in this nifty mount that sticks in place using the included 3M adhesive. I added and zip tie for backup. 200+miles so far with no issues.
Date published: 2017-04-12
Rated 5 out of 5 by from Fantastic Service and Product I had such an amazing buying experience, great product and service...thank you!
Date published: 2017-03-27
Rated 5 out of 5 by from Simply Great! They are awesome. I will definitely buy another set next to the second bike.
Date published: 2017-03-24
Rated 5 out of 5 by from I made the right decision! Before my purchase I spent quite a bit of time trying to decide between the Blue SC and the RPM Speed and Cadence sensors. I ended up going with the RPM bundle as it seemed easier to quickly move between bikes and I was excited to try accelerometer based sensors. Installation was straightforward and quick. After the first couple of weeks and 150 Miles of Las Vegas streets and alleys the sensors have held up well, and the data seems accurate and consistent. I’ve never been an exercise or bicycling person, but having data from the RPM Speed and Cadence sensors and my TCKR heart rate monitor has really turned improving my health into a fun and challenging habit. For once in my life I seem to have made the right decision. ;)
Date published: 2017-03-15
  • y_2017, m_5, d_25, h_13
  • cp_1, bvpage1
  • co_hasreviews, tv_5, tr_71
  • loc_en_US, sid_WFRPMC, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 14.88ms
You may also be interested in the following product(s)
