Free shipping on orders over $55!
Bluetooth and ANT+ Cycling Speed and Cadence Sensor
More Views
SKU# WFBTSC02
€59.99
Shop with 100% confidence
fast international shipping / awesome customer service / no hassle returns within 30 days / limited warranty / get help from a pro (a cycling/running/fitness-loving wahooligan!)
Blue SC Speed and Cadence Sensor Overview
The Wahoo BlueSC speed and cadence sensor transforms your phone into a powerful cycling computer. Using Bluetooth Smart and ANT+ technology, it tracks cycling speed, cadence, and distance which can be paired with your favorite cycling app including Strava and Zwift, or paired to your bike computer. It's weatherproof, small with a low drag profile, and comes with a rubber band and zip tie mounts.
Dual Band Technology
Both ANT+ and Bluetooth Smart capabilities allow for a wireless connection to both smartphones and GPS devices.
Wireless Connection
Speed Measurement
Provides accurate speed data during your ride
Cadence Measurement
Provides accurate cadence data during your ride
Bike Mount Option
BlueSC comes with a rubber band mount and zip tie mount.
Universal Fit
The Blue SC sensor will fit with most bikes and frame sizes
Supported Devices
iPhone
iPhone 4S and newer
Android
Click here for compatible devices
iPad
iPad (3rd gen and newer)
iPod
iPod Touch (5th gen)
Specs
Dimensions (LxWxH): 3.5" x 1" x 3"
Weight: 36 grams
Battery: CR2032
Battery Life: Up to 12 Months
Water Rating: IPX7 (waterproof up to 5 ft)
Wireless Signal Strength: Up to 10 feet
In the Box
BlueSC
CR 2032 Battery (installed)
Mounting Strap
Zipties
Rubber Mounting Base
Crank Arm Magnet
Spoke Magnet
Quick Start Guide
Important Product Info Guide
Product Instructions
Click here for BlueSC instructions
Reviews
Blue SC Speed and Cadence Sensor is rated 4.3 out of 5 by 155.
Rated 1 out of 5 by from Still trying to get it to work. I'd love to be able to tell other prospective buyers that my recently purchased Blue SC is working but so far, I can't tell. The only indication that I am seeing while using the Wahoo fitness app is "I'm Working" shown on the RFLTK display. I don't see my heart rate from the Blue HRM or the speed/cadence from the Blue SC. Maybe I'm doing something wrong.
Date published: 2017-05-02
Rated 5 out of 5 by from Astonishing! I was very sceptic when I decided to purchase the product to be honest. Previously I was using some low-budget, Chinese bike computer with cadence sensor (cable) and it was running perfectly. Then I decided to purchase a Bluetooth kit from one of the market leading brands and... catastrophy! I couldn't even let it communicate with anyof my Android devices. Then I read some reviews of the products similar to Blue SC and I was almost sure it won't work, but I decided to give Wahoo a chance. And you know what- it is my best electronic bike accessory I've bought so far. Once it is paired with the smartphone (Huawei P9) it connects immediately as soon as you get closer to your bike and moves it. It runs reliably- I've made some 700km so far in good as well as severe conditions (-5 degrees Celsius and heavy rains) and it never failed even for a second. It doesn't react as fast as cable sensors of course (due to BT response), but it is precise and reliable. I recommend it to everybody that cares about cadence and to be honest- it is one of the key features you need while biking. All the rest (distance, speed, pace, etc.) you can get even from GPS via dedicated app, but cadence (plus HR) is the key to effective training and Blue SC is the best choice!
Date published: 2017-04-30
Rated 2 out of 5 by from Kind of a pain.. I have two issues. One is that the alignment is really finicky and I have to fiddle with the position before every ride. The second is that I have lost several magnets - I ultimately ended up purchasing a 3rd party magnet from eBay that I secured to the crankshaft with a zip-tie, and that problem was solved. While I haven't tried them yet, the RPM sensors seem like a more solid only because they won't have these issues.
Date published: 2017-04-25
Rated 1 out of 5 by from Easy to Install and Use! Performs great. Installation was a snap and set up easier. Both sensors quickly synced up with my iPhone app and away I went. Have had it for over a month and no issues. I wish all electronic gadgets were this easy. Highly recommend!
Date published: 2017-04-19
Rated 4 out of 5 by from Prefect It is the sensor that I looking for.
Date published: 2017-04-10
Rated 5 out of 5 by from Works better than expected I attached this to my bike while connected to a trainer. Easy install, easy to use app. Works very well.
Date published: 2017-03-20
Rated 5 out of 5 by from Exactly what I wanted I purchased the Blue SC Speed and Cadence sensor for my indoor bike trainer. Installation was simple and 10 minutes after I started I was complete and using the app. I use my indoor bike trainer for cardio day v/s running or the dreaded treadmill. The app is awesome and the best part is being able to easily email the results so i can log it with my other workout stats. Wished i had found this product long ago!
Date published: 2017-03-07
Rated 5 out of 5 by from Great Product I have had this sensor for quite a few years now and it is still going strong. It was easy to install and works great on my trainer and rides outside.
  • y_2017, m_5, d_23, h_3
  • cp_1, bvpage1
  • co_hasreviews, tv_11, tr_144
  • loc_en_US, sid_WFBTSC02, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 75.37ms
Te podría(n) interesar también el/los siguiente(s) producto(s)
