Overview Features Reviews
ELEMNT MINI Bike Computer
€89.99
Simple cycling essentials to stay connected on your ride.
ELEMNT MINI Bike Computer is rated 3.0 out of 5 by 62.
  • y_2019, m_3, d_24, h_16
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_60
  • loc_en_US, sid_WFCC2, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 20.05ms
€89.99
  • Free Shipping On Orders Over €54.99
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
Wahoo ELEMNT MINI is the sensor-based bike computer for those that want max data in a mini package! ELEMNT MINI is designed to work with Wahoo dual-band sensors only and offers two different configurations to meet your ride needs.
  • ELEMNT MINI + RPM Speed: The ELEMNT MINI pairs seamlessly with the Wahoo RPM Speed Sensor included in the box, as well as other Wahoo heart rate monitors and cadence sensors. It works with our free ELEMNT Companion App that allows you to set up your data fields, customize profiles, track performance, and share ride data effortlessly - no more confusing menus!
  • ELEMNT MINI + RPM Speed + Smartphone: When paired to your smartphone, the ELEMNT MINI gives you ride tracking, full ride data analysis, and call & text pop-up notifications.
Works with Wahoo dual-band sensors
The ELEMNT MINI is designed to work with the Wahoo TICKR heart rate monitors and Wahoo RPM speed & cadence sensors. It does not work with Wahoo sensors that are Bluetooth or ANT+ only.
WAHOO RPM SPEED SENSOR INCLUDED
Get on the road in no time! You can quickly pair the ELEMNT MINI and included RPM Speed Sensor be ready to ride in minutes with accurate speed, distance, and time metrics.
Wireless Connection & Uploads
A truly wireless bike computer, meaning there's no need to tether up to your laptop to sync ride data, download routes, or update the software. Everything can be uploaded via Bluetooth to the ELEMNT companion app.
Companion App Set Up
The free ELEMNT companion app allows you to set-up customized profiles, track performance, and share ride data effortlessly.
Fully Customizable Screen
There's a page for every element of your ride. Customize up to 5 pages of the workout data that matters most to you! No menus or reprogramming required.
Smart Buttons
Two tactile and easy-to-press buttons on the bottom of the ELEMNT MINI allow you to quickly navigate to what you want to see and toggle between screens.
Partner App Automatic Uploads
Once synced with your favorite workout or cycling app, you are able send your data from ELEMNT MINI to your account with just one click via the free ELEMNT companion app.
1.8" Diagonal Screen Size
1.8" (45.7mm) diagonal display size that is larger than the leading competitor, so all your data is easy to see.
Ride Tracking When Paired to Phone*
When paired with your smartphone, record your ride via the smartphone's GPS so you have a full ride history of your route and ride statistics.
Live Track Portal When Paired to Phone*
With Live Track, you can share a custom link with anyone via the ELEMNT Companion App so they are able to follow your ride in real-time on the Live Track web portal. Perfect for keeping you safely located by loved ones, tracked by a coach, or even meeting fellow riders in-route.
Text & Call Notifications When Paired to Phone*
Provides on-screen pop-up notifications to alert you when important contacts are trying to call or text. Available when you are riding with your smartphone.
*In phone mode, your smartphone must be with you on the ride and your ELEMNT MINI must be paired to the ELEMNT companion app.
Click here for ELEMNT MINI instructions
Specs
Part Number: WFCC2
Physical Dimensions: 41x58.4x17mm OR 1.6x2.3x.67"
Display Size: 1.8" (45.7mm)
Weight: 1.1 oz or 31 grams
Battery: Coin Cell
Battery Life: ~1 Year
Waterproof Rating: IPX7 (waterproof up to 5 ft)
Shock Proof: Yes
Wahoo RPM Speed sensor included
Rated 5 out of 5 by from Excellent product that works well I needed a simple cycle computer that would provide me with real-time heart-rate and speed information. The Element Mini does this very effectively and I am pleased with its performance. It is well-engineered, easy to use and connects automatically to the Wahoo Tickr and Speed sensors. I run it stand-alone as to reduce the load on my phone. The Mini comes with a secure mounting and I have it sitting on the top of the stem, immediately behind the bars. This makes it easy to see and it is mainly out of the wind. So, an excellent product if a little expensive.
Date published: 2018-08-31
Rated 5 out of 5 by from Simple, Clear, Comprehensive The mini offers all of the key features I need for training: it includes the cadence, speed, distance, and heart rate. There may be greater configuration options as well but it is fine out of the box!
Date published: 2018-07-06
Rated 5 out of 5 by from Works well I bought the Elemnt after a poor experience with Wahoo's Reflkt, including sporadic connectivity with HR strap, cadence sensor, and iPhone. I chose the Elemnt Mini because of three reasons: it provides the data I want, DCrainmaker.com said it worked as advertised, and Wahoo offers a 30-day no questions return policy. I've used it on 18 rides and, so far, it has worked well - same bike, rider, phone, sensors, jersey, etc. as I used with the Reflkt. Don't let a poor experience with Reflkt influence your decision.
Date published: 2018-05-11
Rated 5 out of 5 by from Wonderful Mini The Wahoo Mini is exactly what I was looking for. Small, simple and chic. Nevertheless, it offers everything you need or you can extend it. It was also very important to me not to have a touchscreen, just keys, and also a nice sensor for the speed, which does not spoil the design of my bike. Just like the included holder, but I added the Out Front Mount to it. The connection to the smartphone via Bluetooth is also successful, as well as the tracking of the route in connection with the smartphone and even with hardly any more power consumption on the smartphone. Just wonderful the little wahoo :-)
Date published: 2018-02-12
Rated 5 out of 5 by from great non-gps bike computer! i bought this computer as my previous "standard" bike speedometer / computer with its temperamental sensors on the fork / spoke and lack of per ride information was a bit frustrating. the mini had a few syncing issues at first but all were solved by the attentive and helpful wahoo support service. the mini has a lot of great features - can be paired with your phone or run on its own. the pages can be customized so you can focus on the information you are interested in - with lots of options - mileage, average speed, etc. the sensor on the hub is nice and neat. it syncs my rides perfectly to strava every time. in the winter it is nice to not have to get out your phone to start / stop your strava app in the cold with numb fingers! would definitely recommend this!
Date published: 2018-01-09
Rated 5 out of 5 by from Great option to get just the right amount of data! Choosing which computer I'd buy, I looked at both the Bolt and the Mini. At the end of the day, the Bolt seemed like an overkill. I like the Mini's simplicity and being realistic, I don't need the power data. I'm neither that competitive nor that obsessed. Maybe that's why. However, I have enjoyed comparing current vs. average speed and having my heart rate always visible. It has even already improved my performance. I've read a lot of comments about technical issues with the device, which made me nervous. But I can confidently say they are most-likely user issues and not device issues. I, for once, didn't get the "distance" value from my first ride, then I realized it was because of my phone GPS settings. Enabled the Wahoo app to see my location at all times (instead of "only when using") and it was all solved. Bonus: the companion phone app works pretty well, it doesn't bite that much battery (on my iPhone SE at least) and it offers good performance analysis, including power zones, which is a tad better than just logging stuff on Strava. Great choice if you're new to bike computers and don't require something overwhelming on both data and price. Works specially well if you already have some Wahoo sensors.
Date published: 2018-01-08
Rated 5 out of 5 by from lots of features in a little computer Having the bolt myself bought this for my brother in law for Christmas. he loves it. not as many features as the bolt but can be used with alot of outside apps.
Date published: 2018-01-07
Rated 5 out of 5 by from Great for E-Bikes! My wife and I are in our 70s and found that our favorite sport of bike riding was getting more difficult especially climbing hills. We purchased e-Bikes but found that we weren’t getting the exercise that we wanted. Our solution was to purchase element minis and start tracking cadence and heart rate. The mini provides all the info that we need plus the convenience of not having to constantly recharge the units. Recently we did a 4 day tour and they functioned perfectly. Great product at a very reasonable price.
Date published: 2017-12-21
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.53ms
Product Overview
Smart Buttons
For more info, see Faq
Specs
Part Number: WFCC2
Battery: Coin Cell
Shock Proof: Yes
Reviews
