Overview Features Reviews
KICKR Headwind Bluetooth Fan
€229.99
Control your climate.
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 2.58ms
€229.99
  • Free 2-4 Day Shipping
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
The KICKR HEADWIND is the first ever smart fan, designed with the cyclist in mind. It's Targeted Airflow Pattern mirrors the shape and position of a cyclist's body while riding. The KICKR HEADWIND is sensor controlled so as your speed or heart rate increases, so will the fan speed, and there are also 4 manual speed settings should you want to set your own ideal airflow. With speeds of over 30 mph (48 kph), the KICKR HEADWIND will keep you cool during the toughest training sessions.
Powerful Airflow
With wind speeds topping out at over 30 mph the KICKR HEADWIND will keep you cool during your hardest efforts.
The Targeted Airflow Pattern of the KICKR HEADWIND is designed to mirror the shape and position of a cyclist's body while riding on a bicycle.
Sensor based fan speed control
Control the speed of your KICKR HEADWIND by pairing your ANT+ speed sensor, heart rate monitor, or smart trainer directly to the fan. As your speed or heart rate increases so will the fan speed.
App based fan speed control
Pair to the Wahoo App via Bluetooth for easy fan speed control at your fingertips.
4 Manual Fan Speeds
Control the KICKR HEADWIND with a simple press of a button. Four (4) preprogrammed fan speeds allow you to select your ideal airflow.
KICKR DESK Compatible
The KICKR HEADWIND was specially designed to fit with the KICKR DESK. The wheels on the KICKR HEADWIND allow you to roll the fan into position when it is attached to your KICKR DESK.
Specs
  • Part Number: WFBKTR7EU
  • Motor Spec: 240v 50/60hz
  • Dimensions (leg tucked): 16"L x 12"W x 19"H
  • Dimensions (leg extended): 18"L x 12"W x 19"H
  • Weight: 12 lb
  • Max Fan Speed: 30 mph/48 kph
  • Connectivity:
    • Bluetooth - Pair to phone to control the fan speed via app
    • ANT+ - Pair to speed sensor, heart rate monitor, or smart trainer to control fan speed
  • Adjustable Leg: Yes - 2 Positions
  • CLOUD, getReviews, 2.31ms
Product Overview
Powerful Airflow
4 Manual Fan Speeds
For more info, see Faq
Specs
  • Weight: 12 lb
  • Connectivity:
Reviews
