Overview Reviews
KICKR 12x142 Thru Axle Adapter
€29.99
For the Wahoo KICKR 2014 and 2016 editions
Out of Stock
KICKR 12x142 Thru Axle Adapter is rated 4.0 out of 5 by 28.
  • y_2019, m_3, d_24, h_16
  • cp_1, bvpage1
  • co_hasreviews, tv_2, tr_26
  • loc_en_US, sid_WFKICKR142, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 42.6ms
€29.99
  • Free Shipping On Orders Over €54.99
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
This kit comes with everything you need to mount most 12x142 thru-axle bikes on your KICKR indoor trainer. It will work only with the 2014 and 2016 editions of the KICKR. It includes the following:
  • Threaded Axle Spacer
  • Hub Width Adapter
  • Conical Axle Adapter
  • Flat Axle Adapter
  • XL Quick Release Skewer
  • Extended Quick Release Nut
Note: The KICKR is not compatible with the thru-axle itself; instead, we use this adapter kit to secure the bike in place. Please watch the installation video or read the adapter instructions before attempting to install yourself. This is for 12x142 bikes only. Not compatible with 12x135, 12x148, or any other thru-axle system. If you have any questions, don't hesitate to contact us!
Click here for Adapter instructions
Rated 5 out of 5 by from Just Works Updated my KICKR Gen1 with zero issues. Works perfectly.
Date published: 2018-09-10
Rated 5 out of 5 by from works well I bought this 12x142 thru axle adaptor for my 1st generation KICKR so I could use me new bike that has thru axles and disc brakes. (2017 Venge ViAS Pro Disc) I simply watched the video regarding replacement of the quick release axle with the thru axle adaptor, super simple and quick to complete and has worked flawlessly!
Date published: 2018-02-23
Rated 5 out of 5 by from Works on a 2018 Roubaix Installed fairly easy. Seems to work just fine with a 2018 Specialized Roubaix Di2.
Date published: 2018-02-20
Rated 5 out of 5 by from Perfect fit for the Wahoo Snap trainer I received a Wahoo Snap for Christmas, turns out I needed a Thru Axle adapter because my Cyclops didn't work. The Wahoo Thru Axle is a perfect fit. One issue is depending on your bike it might get close to the frame. I have a 2017 BMC Roadmachine 02 carbon bike and I had to put a small spacer in the left side of the trainer so that it gave some clearance from my frame. Otherwise it is a perfect fit.
Date published: 2018-01-15
Rated 5 out of 5 by from Perfect Fit! I've had this for about 3 weeks now and I ride the trainer about 4-5 time a week (45 minutes - 1 hour 30 minutes) and have had no issues with it. I'm using it on the Wahoo Kickr and it's a perfect fit! Easy to use!
Date published: 2018-01-11
Rated 5 out of 5 by from Great product! Have had it for a week now works great and the ease of converting was simple and easy.
Date published: 2018-01-04
Rated 5 out of 5 by from Does what it is suppose to do. Not much to say really but works exactly as I'd expect it to.
Date published: 2017-10-19
Rated 5 out of 5 by from Not just for mountain bikes My latest road bike - Specialized Ruby - has a thru axle (much to my surprise). I didn't realize that it wouldn't work with the Kickr as is. Discovered this adapter and it works like a charm. There are directions that come with it that are so-so, but if I can figure it out, anyone can. After a little practice, I can switch out my tri bike and my road bike that use different skewers on the Kickr in less than a minute.
Date published: 2017-07-12
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.71ms
Product Overview
  • Hub Width Adapter
  • Flat Axle Adapter
For more info, see Faq
Specs
Reviews
