Overview Reviews
Wahoo Smart Trainer Colored Chevrons
€19.99
Wahoo Smart Trainer Colored Chevrons is rated 2.3 out of 5 by 7.
  • y_2019, m_5, d_20, h_22
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.12
  • cp_1, bvpage1
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_WFCHEVRONS, prod, sort_[SortEntry(order=RATING, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 3.06ms
€19.99
  • Free 2-4 Day Shipping on Orders over €54.99
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
Customize your KICKR, KICKR CORE, or KICKR SNAP with these vinyl chevron decals. They come in a variety of colors and can be placed directly over or in between the standard grey chevrons.
  • KICKR chevrons fit 2018 Edition KICKR
  • KICKR CORE chevrons fit 2018 Edition KICKR CORE and 2014, 2016, and 2017 Edition KICKR
  • KICKR SNAP chevrons fit 2015 and 2017 Edition KICKR SNAP
Rated 5 out of 5 by from Look really great I’ve just fitted these chevrons to my 2017 kickr only to find that there wasn’t enough to go round (2x short) as I purchased the 2018 version by mistake. Please make sure you order the correct ones for your model.
Date published: 2018-09-19
Rated 3 out of 5 by from A bit of fun! Just thought I'd brighten up the grey Kickr with these yellow chevrons. They come as individual chevrons on a strip (exactly the right number for one flywheel - no spares if you tear one!). They peel off the backing and go on quite easily with a bit of care, took me about twenty minutes to put them on. They are exepensive for what they are and when you add Wahoo's shipping costs on top I can't say they're value for money! The backing strip they came on was folded through some of the chevrons but the creases smoooth out once they're applied - might be better on a cardbord roll or similar. As I said - just a bit of fun.
Date published: 2018-09-23
Rated 3 out of 5 by from Ever spray paint your bike? I received the yellow chevrons as a freebie. I thought they might increase my FTP so I put them on the flywheel. They had no noticeable affect on either my FTP or my chances of winning the Tour de France. They were a little difficult to put on straight so now it looks as if my flywheel has a slight wobble. Since no one sees it, it doesn't matter. Very cool if you're ten years old.
Date published: 2018-08-17
Rated 2 out of 5 by from Okay I was disappointed about the packaging; it was folded multiple times right through the yellow arrows. I think it wouldn't be much of an issue to align the folding mechanism once to avoid that.
Date published: 2018-06-21
Rated 1 out of 5 by from don't waste money & time - my kickr is now bald! First set of these arrived, but they were way smaller than the originals and didn't stick. Contacted customer support, after some time a replacement set arrived ... this time they were the right size but were cut from the same Hexis car vinyl wrap/sticker material which it would seem does not like to adhere at all to the rough surface of the kickr core's resistance unit ... so again, stickers went flying across the room within minutes of first use! ... both times prior to applying I made sure the surface was 100% clean and dry, free from all dust etc, then pressed and rubbed each of the stickers into place and allowed to sit for a while before using the kickr. Whether they stick or not, I would suggest these really are not great value for money ... I previously owned a cutter / plotter and the cost of producing these stickers is in the realms of a few cents. Very disappointed and not once but twice ... my kickr is now bald and looking quite sorry for itself ... The material these are made from is not the same as the original stickers, so despite them looking nicer, would recommend not switching and sticking with the grey.
Date published: 2018-12-19
Rated 1 out of 5 by from Junk Great idea, but these don’t adhere to the flywheel well at all. Within a week of apply, about half had fallen off. Took them all off and threw them in the trash.
Date published: 2018-11-25
Rated 1 out of 5 by from Good idea but poor installation = epic fail I bought the yellow chevrons to put in the gaps between the standard grey chevrons. One would think the chevrons would be evenly spaced so that you would just have to line up the replacements all at once for a fairly simply application. No dice. Needless to say I ended up throwing away the whole thing. Total waste of money.
Date published: 2018-08-30
  • cp_1, bvpage1
  • CLOUD, getReviews, 2.42ms
Product Overview
For more info, see Faq
Specs
Reviews
