Free shipping on orders over $55!
KICKR SNAP Bike Trainer
The most realistic ride experience of any wheel-on bike trainer.
More Views
SKU# WFBKTR2
€549.99
Shop with 100% confidence
fast international shipping / awesome customer service / no hassle returns within 30 days / limited warranty / get help from a pro (a cycling/running/fitness-loving wahooligan!)
KICKR SNAP Bike Trainer Overview
The Wahoo KICKR SNAP brings a realistic ride experience indoors and into a wheel-on smart trainer. The SNAP's legendary flywheel features technology that creates the same resistance experienced in outdoor climbs and descents. Plus, no other indoor bike trainer has more software training options, including Zwift and Trainer Road. Join the Wahoo Fitness family and become a part of the most connected cycling experience - both indoors and outdoors.
BONUS! When you register your KICKR SNAP in the Wahoo Fitness app, you'll receive these awesome offers from our partners
PLEASE NOTE: The KICKR only ships to select countries. Signature required for delivery of all KICKR shipments.
Dual Band Technology
Both ANT+ and Bluetooth Smart capabilities allow it to connect to both smartphones and GPS devices simultaneous or separately
Convenient Design
SNAP's wheel-on design makes it easy to turn your regular road or mountain bike into a powerful indoor smart trainer.
Super Stability
Made from high strength carbon steel and featuring a wide stance, SNAP is designed to keep its feet firmly planted on the floor and your bike securely locked in so you can train with confidence.
Reliable power measurement
Designed for consistent power measurement so that you can monitor and adjust your intensity. Accurate to +/- 5%.
Controlled resistance
When connected to your device, it automatically sets your resistance via your favorite app or software
Realistic road feel
The SNAP flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic road feel especially when using virtual riding/training platforms like Zwift and Trainer Road.
Measures speed, distance, and power.
Get vital cycling metrics on your indoor ride.
Reduced Noise
Super quiet; no shouting required!
ANT+ FE-C Control
The SNAP now has ANT+ FE-C support, which allows the SNAP to be controlled from any FE-C enabled device or application, including products like Garmin bike computers.
Third Party App Compatibility
Works with popular training apps such as Kinomap, Virtual Training, and TrainerRoad
Includes free 60 day strava premium membership
After registering your KICKR in the Wahoo Fitness app, you will receive access to and the ability to redeem 2 months free of Strava Premium. Not valid for existing Strava Premium members. Learn more about the offer.
Includes free 30 day TrainerRoad membership
After registering your KICKR in the Wahoo Fitness app, you will receive access to and the ability to redeem 1 month free of TrainerRoad Learn more about the offer.
Includes free 60 day Sufferfest Training Centre membership
After registering your KICKR in the Wahoo Fitness app, you will receive access to and the ability to redeem 60 days free of The Sufferfest Learn more about the offer.
Supported Devices
iPhone
iPhone 4S and newer
Android
Click here for compatible devices
iPad
iPad (3rd gen and newer), iPad Mini
iPod Touch
iPod Touch (5th gen and newer)
Mac Book
BTLE enabled or when paired with an ANT+ dongle
Windows PC
Specs
Dimensions (legs open):29"" x 26"" (74cm x 66cm)
Weight: 38lbs
Rear Wheel size: 650c RD / 26"" MTB / 700c RD / 650b MTB / 29"" MTB
Hub Types: 130mm and 135mm Quick Release and 142x12 Thru-Axle with adapter
Drivetrain: N/A
Metrics: Speed, power, distance
Front wheel block: Included
Resistance type: Electromagnetic
Accuracy: +/- 5%
Wireless software updates: Yes
3rd party power meter support: No
Connectivity: ANT+, ANT+ FE-C, and Bluetooth Smart
Devices: iOS / Android / PC (Mac and Windows)
Max User Weight: 250 lbs
Power Requirements: 100-240V~1.5A 50-60 Hz
Flywheel Weight: 10.5 lbs
Maximum Simulated Grade: 12%
Maximum Power Output: 1500 Watts
In the Box
KICKR SNAP
Front wheel block
Power cord
Power brick
Quick release skewer
Quickstart guide
Reviews
KICKR SNAP Bike Trainer is rated 4.4 out of 5 by 133.
Rated 3 out of 5 by from Quiet, easy to work with, sensor drops Excited to get this trainer and use it with zwift. I quickly found the power readings were unexpectedly low and believe the sensor isn't dropping out. Even on the wahoo utility app the Bluetooth sensor reads 50-60% at best which is trouble and I believe a source of getting dropouts. I've also tried using an ant device an inch from the flywheel. If the sensor in the flywheel isn't strong enough to work with a iPhone sitting on your handlebars what is the point. I will be putting in a ticket to wahoo because I don't think this working correctly.
Date published: 2017-05-06
Rated 1 out of 5 by from Go for the Kickr instead of Kickr Snap I bought the kickr snap to save some money compared to the Kickr. After using the Kickr Snap 4 times my rear wheel got burned because of a extremely hot roller. Apparently the only thing I did differently was to increase the resistance %. Now I have a damaged tyre that I have to replace because I use the bicycle also to ride outside. Not only that, I have to buy an additional wheel with a special training tyre, in order not to be changing the tyre all the time I train on the roller or on the roads. So +200 € I didn't expect. Also there are no clear instructions in how to tighten the roller, how to check if the spin down was correct and so on.
Rated 5 out of 5 by from Perfect solution to make the use of a trainer fun. I bought the trainer with the intention of spending more time riding inside following two serious cycling accidents. I'm 63 y/o and am now moderately disabled from a vertebral blow out fracture and ruptured disc. I recently had another crash resulting in 13 fractures and a collapsed lung. I ride with friends of mine on Zwift. In retrospect, I wished I'd spent the additional $500 and bought the direct drive Wahoo kickr so I would need to deal with the regular calibration needed to keep the wheeled model accurate. You can train a lot harder on line because you don't need to beware of dogs, cars, stop signs and stop lights.
Date published: 2017-04-28
Rated 5 out of 5 by from Indoor cycling re-born The KICKR SNAP trainer gives you a reason to ride inside. It's easy to setup and when coupled with Zwift lets you ride when weather is bad and have some fun doing it. Gone are the days riding when the weather is sketchy or when I'm strapped for time. I can ride daily. Fantastic product.
Rated 5 out of 5 by from Excellent Smart Trainer! I love my Kickr Snap! It's prefect for focused training with 3rd party apps/software. I would recommend this as an investment for any cyclist that wants to get more serious about focused training. I am currently using my Snap with a 2017 Norco Threshold.
Date published: 2017-04-27
Rated 5 out of 5 by from Great for the money It has all the modern features, it is faultless and vell ... quiter than my wifes VW Polo diesel. It looks, feels and actualy is solid. I do not like the blue/red diodes flashing on it however.
Date published: 2017-04-25
Rated 5 out of 5 by from Amazing! So happy I decided to buy the Snap!
Date published: 2017-04-17
Rated 4 out of 5 by from Awesome! Really like it, true road feel design and works really well with Zwift. Having some trouble with wattage drop outs but am sure it's probably user error. The product is really well built and easy to use.
Date published: 2017-04-14
  • y_2017, m_5, d_23, h_1
  • cp_1, bvpage1
  • co_hasreviews, tv_3, tr_130
  • loc_en_US, sid_WFBKTR2, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 75.34ms
You may also be interested in the following product(s)
