As endurance athletes, you understand that marginal gains matter. You’ve dialed in your training zones, perfected your pacing strategy, and optimized your gear. But nutrition remains the most underutilized performance variable in endurance sports. The difference between a PR and a DNF often comes down to fuel management, not fitness.
This guide examines the metabolic demands of endurance racing and provides the evidence-based strategies that separate good athletes from great ones.
The Metabolic Reality of Endurance Racing
Energy Systems and Substrate Utilization
During endurance events, you’re operating primarily in the aerobic energy system, but the fuel mixture shifts dramatically based on intensity and duration. For example, when racing at marathon pace—typically 75-85% VO₂ max for competitive runners—you’re burning approximately 50-65% carbohydrates and 35-50% fat. For competitive Ironman racing, the fuel mix shifts notably because of the event’s duration (8–17 hours) and variable intensity across swim, bike, and run. Well-trained Ironman athletes develop a greater capacity to spare glycogen and rely on fat metabolism, allowing them to sustain effort for many hours. However, carbohydrates remain essential for maintaining power output, especially in the latter stages of the bike and throughout the run. Whether running marathons or racing Ironman, understanding this metabolic reality is crucial because it directly informs your fueling strategy.
The numbers tell a stark story. Carbohydrate oxidation rates during marathon-intensity exercise range from 2.5-4.0 grams per minute, while total energy expenditure hovers between 600-900 kilocalories per hour, varying significantly based on body weight and mechanical efficiency.
Your glycogen stores, meanwhile, provide only 400-600 grams in muscle tissue and 80-120 grams in the liver, translating to roughly 1,920-2,880 total kilocalories. While your fat stores are virtually unlimited for energy purposes, they cannot be accessed quickly enough to sustain marathon pace without carbohydrate support.
This creates the fundamental challenge of marathon fueling. Even the most glycogen-loaded runner will deplete stores in 90-120 minutes at race pace without external fueling. This mathematical reality explains why sub-elite and elite marathoners consume 60-90 grams of carbohydrates per hour; they’re not following arbitrary guidelines but responding to metabolic necessity.
For Ironman, the numbers look different but tell a similar story. During Ironman-intensity exercise—typically 60–75% of VO₂ max—carbohydrate oxidation rates average 1.0–2.0 grams per minute, with total energy expenditure ranging from 500–800 kilocalories per hour, depending on body size, terrain, and efficiency.
Even though fat contributes a larger share of fuel at this intensity, glycogen stores remain finite—roughly 2,000–3,000 kilocalories total—and will still be heavily taxed over 8–17 hours of racing. Without consistent carbohydrate intake, athletes inevitably face glycogen depletion, leading to sharp declines in power, coordination, and cognition.
That’s why competitive Ironman athletes typically aim for 60–100 grams of carbohydrates per hour, strategically timed across bike and run legs to balance absorption rates, gut comfort, and sustained performance.
The Physiology of Glycogen Depletion
Glycogen depletion doesn’t happen uniformly throughout your body, and understanding this pattern is key to managing race-day energy. Type I slow-twitch muscle fibers preferentially utilize fat as fuel, while Type II fast-twitch fibers rely heavily on glycogen. As glycogen stores diminish, a cascade of physiological changes occurs that extends far beyond simple fuel shortage.
Neural drive decreases as the central nervous system’s protective mechanisms kick in—what researchers call the central governor theory. Simultaneously, calcium release within muscle cells becomes impaired, creating peripheral fatigue that compounds the central nervous system effects. Lactate buffering capacity diminishes, and perhaps most importantly for competitive endurance athletes, perceived exertion increases disproportionately to actual workload. This cascade explains why “hitting the wall” or “bonking” isn’t merely about empty fuel tanks—it represents comprehensive metabolic system failure.
Periodized Nutrition: Training Your Metabolism
Base Phase I: Building Metabolic Flexibility
During base building phases, your nutrition goals extend far beyond simply fueling workouts. You’re training your body to become a more efficient fat-burning machine while maintaining carbohydrate sensitivity, a delicate balance that requires strategic manipulation of macronutrient intake.
Daily macronutrient targets during base-phase training should emphasize moderate carbohydrate intake to enhance fat adaptation while supporting training quality. Carbohydrates should comprise 5-7 grams per kilogram of body weight daily, protein intake should range from 1.6-2.2 grams per kilogram (with higher intake during particularly high-volume weeks), and fat should contribute 1.0-1.5 grams per kilogram daily, with emphasis on omega-3 fatty acids for their anti-inflammatory properties.
Sleep and recovery nutrition take on heightened importance during high-volume base phases. Consuming 20-40 grams of protein before bed during these periods can increase overnight muscle protein synthesis and promote repair. This seemingly small intervention can significantly impact your ability to adapt to training stress and maintain health throughout demanding training blocks.
Build Phase II: Optimizing Training Adaptations
As training intensifies and workout specificity increases, your nutrition must evolve to support both performance and recovery. This phase introduces the concept of periodized carbohydrate intake, where daily fuel availability matches training demands with surgical precision.
The philosophy behind periodized carbohydrate intake centers on providing adequate fuel for quality sessions while maintaining metabolic flexibility on easier days. Easy training days warrant 5-7 grams of carbohydrates per kilogram, medium-intensity days with tempo work or moderate long runs or rides require 7-9 grams per kilogram, while hard days featuring intervals or race-pace work demand 8-12 grams per kilogram to support training quality and subsequent recovery.
Pre-workout fueling becomes increasingly sophisticated during build phases. For sessions beginning 1-4 hours after your last meal, consume 1-4 grams of carbohydrates per kilogram with minimal fat and fiber to optimize gastric emptying. When timing is tighter, such as 30-60 minutes before key sessions, 15-30 grams of easily digestible carbohydrates from sources like dates, bananas, or sports drinks provide readily available glucose.
Intra-workout fueling guidelines become essential for longer or more intense sessions. Any workout exceeding 90 minutes benefits from 30-60 grams of carbohydrates per hour, while sessions lasting longer than 2.5 hours require 60-90 grams per hour—treating these as opportunities to practice race-day fueling protocols. Even high-intensity interval sessions benefit from 30-40 grams of carbohydrates per hour to maintain quality throughout the workout and optimize recovery.
Peak Phase: Race Preparation
For marathon racing:
The final 2-3 weeks before your race require absolute precision in both training and fueling. This period represents the culmination of months of metabolic training, where every nutritional decision either enhances or undermines your preparation.
In days 7 to 4 before your marathon: Maintain normal training with moderate carbohydrate intake of 5-7 grams per kilogram daily.
In the final three days: This is where the magic happens; training volume drops significantly while carbohydrate intake increases to 8-12 grams per kilogram daily, effectively supercompensating glycogen stores beyond normal levels.
Race morning: Fueling represents the final piece of your preparation puzzle. Consuming 1-4 grams of carbohydrates per kilogram, 3-4 hours before race start provides readily available glucose while allowing sufficient time for gastric emptying. This meal should be familiar, tested during training, and emphasize easily digestible sources.
For Ironman racing:
The final 2–3 weeks before an Ironman demands precision—not just in tapering your training load but in managing nutrition to maximize glycogen stores, hydration, and gut readiness. This period is about arriving on the start line fueled, fresh, and physiologically primed for a long day of sustained output.
In days 14 to 7 before your Ironman: Training volume will be reduced but continue with moderate carbohydrate intake of 5–7 grams per kilogram daily. Prioritize whole-food sources, adequate protein (1.6–1.8 g/kg), and consistent hydration with electrolytes to support recovery and muscle glycogen replenishment.
In the final 3–4 days: Although training volume is low (with some intensity to keep the body feeling sharp), carbohydrate intake increases to 8–10 grams per kilogram daily to fully saturate glycogen stores across muscle and liver tissue. Because Ironman racing draws on glycogen for many hours, this extended loading period ensures deeper energy reserves than a marathon taper alone. Focus on low-fiber, easily digestible carbs, and maintain sodium and fluid balance to avoid bloating or GI discomfort.
Race morning: Consume 1–4 grams of carbohydrates per kilogram body weight about 3 hours before the start, emphasizing familiar, low-fiber foods that digest easily—such as rice, oats, or white bread with honey or jam. Include electrolytes and a small amount of protein if tolerated. In the final hour, sip on a carbohydrate-electrolyte drink and take a gel ~30 minutes pre-swim to top up blood glucose levels.
Advanced Hydration and Electrolyte Management
Sweat Rate and Sodium Loss Testing
Competitive athletes cannot rely on generic hydration recommendations as individual variability in sweat rates and electrolyte losses demand personalized strategies. Conducting sweat testing under race-like conditions provides the data necessary for optimal hydration planning.
Calculating your sweat rate requires precision but delivers invaluable insights. The formula involves weighing yourself before and after exercise, accounting for fluid intake and urine output, then dividing by exercise duration. This simple calculation reveals whether you’re a low, moderate, or high sweater—information that fundamentally shapes your hydration strategy.
Sodium loss testing adds another layer of personalization. Sodium loss rates vary dramatically between individuals, ranging from 200 milligrams per liter in some athletes to over 2,000 milligrams per liter in others. This 10-fold variation explains why generic recommendations often fail competitive athletes. Practical hydration targets emerge from this testing. During recovery periods, replace 125-150% of sweat losses to account for ongoing fluid losses and ensure complete rehydration. During racing, replace 400-800 milligrams of sodium per hour as a baseline, adjusting upward by 200-400 milligrams per hour in hot or humid conditions. Monitor urine color as a simple indicator of hydration status, aiming for pale yellow to indicate adequate hydration.
Advanced Electrolyte Considerations
Beyond sodium, competitive endurance athletes should consider the full spectrum of electrolyte losses. Potassium needs increase to 150-300 milligrams per hour during ultra-distance efforts, while magnesium requirements reach 50-100 milligrams per hour, particularly important for athletes prone to cramping. Calcium, often overlooked in sports nutrition, contributes 50-100 milligrams per hour to optimal muscle contraction and should be included in comprehensive electrolyte strategies.
Gut Training: The Fourth Training Zone
Your gastrointestinal system represents trainable tissue, responding to repeated stimuli much like your cardiovascular or muscular systems. Research from Asker Jeukendrup’s laboratory demonstrates that carbohydrate transporter proteins—specifically SGLT1, GLUT2, and GLUT5—upregulate with consistent exposure to high-carbohydrate intake during exercise. This adaptation allows your gut to process and absorb significantly more fuel during competition than untrained digestive systems can handle.
Progressive Gut Training Protocol
Gut training follows progressive overload principles similar to physical training. Beginning with weeks one and two, target 30-40 grams of carbohydrates per hour during long runs, focusing on tolerance and comfort rather than pushing limits. Weeks three and four increase intake to 45-60 grams per hour, introducing variety in carbohydrate sources and timing. Weeks five and six push toward 60-75 grams per hour during long runs, while week seven and beyond target the 75-90 gram per hour range during race-pace segments.
Carbohydrate source optimization becomes critical when targeting higher intake rates. Research consistently shows that using 2:1 or 3:1 glucose to fructose ratios enables intake exceeding 60 grams per hour by utilizing multiple intestinal transport pathways. Practice with various carbohydrate sources including gels, sports drinks, and solid foods to determine individual preferences and tolerance patterns. Solution concentration limits typically fall between 6-8% for optimal gastric emptying and intestinal absorption.
When gastrointestinal distress occurs during training, systematic troubleshooting identifies solutions. Reducing fiber intake 24-48 hours before key sessions minimizes gut residue that can interfere with absorption. Avoiding high-fat foods 3-4 hours before exercise prevents delayed gastric emptying. Consider probiotic supplementation during heavy training blocks to support intestinal health, and practice caffeine timing and dosage—typically 3-6 milligrams per kilogram consumed 30-60 minutes before racing—to optimize benefits while minimizing gastric upset.
Race-Specific Fueling Strategies
Pre-Race Protocol: 48 Hours Out
Carbohydrate loading refinement in the final 48 hours requires meticulous attention to detail. Target 10-12 grams of carbohydrates per kilogram daily for the final two to three days, emphasizing low-residue sources like white rice, pasta, and potatoes that minimize intestinal bulk while maximizing glycogen storage. Reduce fiber intake to less than 10 grams daily during this period to minimize gastric residue, while maintaining protein intake at 1.2-1.6 grams per kilogram to support muscle protein synthesis. Most importantly, avoid any new foods entirely during this critical window.
Hydration preparation begins 24 hours before competition with mild hyperhydration protocols. Consume 5-7 milliliters of fluid per kilogram of body weight every 2-3 hours, including 300-500 milligrams of sodium per 16-20 ounces of fluid to enhance retention and optimize plasma volume expansion.
Race Morning Execution
Race morning nutrition represents the final opportunity to optimize fuel availability before competition. Timing and composition matter enormously, with the ideal window falling 3-4 hours before race start. This meal should provide 200-300 grams of easily digestible carbohydrates with minimal protein and very low fat and fiber content. Familiar foods take precedence over optimal foods, as gastrointestinal comfort trumps theoretical advantages.
For traditional breakfast preferences, consider a large bowl of oatmeal with banana, honey, and coffee. Athletes preferring liquid calories might choose 16-24 ounces of sports drink with a white bagel and jam. Those with nervous stomachs often tolerate 2-3 servings of sports drink with a small amount of white rice better than solid food combinations.
Final pre-race fueling occurs 30-60 minutes before competition and should be minimal; 15-30 grams of carbohydrates if comfortable, individualized caffeine dosing if part of your strategy, and small sips of electrolyte solution to maintain hydration status without causing gastric distress.
In-Race Fueling Execution: Marathon
Early miles from start through 10 kilometers should focus exclusively on hydration, with small sips every 2-3 kilometers. Avoid early fueling unless your race exceeds three hours, as glycogen stores remain adequate and early carbohydrate intake can interfere with optimal pacing and thermoregulation.
Middle miles from 10 to 30 kilometers represent the critical fueling window where race outcomes are determined. Begin carbohydrate intake targeting 60-90 grams per hour, consuming fuel every 5 kilometers in 15-20 gram portions. Alternate between different carbohydrate sources to optimize absorption and prevent flavor fatigue. Continuously monitor subjective fueling tolerance, adjusting intake based on gastric comfort rather than rigid adherence to predetermined schedules.
The final segment from 30 kilometers to finish tests your fueling strategy under maximum physiological stress. Maintain carbohydrate intake if gastric tolerance permits, as glucose needs remain high even as gastric emptying may slow. Consider a caffeine boost if not used earlier in the race, switch to more concentrated carbohydrate sources if stomach issues develop, and prioritize fluid intake over solid fuel if gastrointestinal distress becomes problematic.
In-Race Fueling Execution: Ironman
Aside from a gel ~30 minutes prior to the swim start to help keep blood sugar levels topped up, the real fueling begins on the bike in an Ironman race—and fueling discipline here can hugely impact the rest of your race. Start early—within the first ~15 minutes of the bike—once your heart rate has settled and your legs are finding rhythm. Aim to consume 60–90 grams of carbohydrate per hour, scaling toward 90–110 g/hr for elite or well-trained athletes. Combine multiple transportable carbohydrates (glucose + fructose blends) in your fueling plan, and target approximately 500–750 ml of fluid per hour, adjusted for conditions. Sodium intake of 400–800 mg/hr helps offset sweat losses and supports fluid absorption. Consistency is key: steady intake every 10–15 minutes prevents energy dips and minimizes gastrointestinal strain. Many athletes set an alarm reminder on their bike computer or watch to help keep them on schedule.
The Ironman marathon begins on depleted glycogen and reduced digestive tolerance, making precision more critical than pace. Begin fueling within the first 10–20 minutes of the run—typically 30–60 grams of carbohydrate per hour, depending on tolerance and previous bike intake. Remember that the bike is really the buffet of Ironman fueling; fueling as you get deeper into the marathon becomes significantly harder.
Liquid or gel forms are preferable to solids for ease of absorption, with fluids used to wash down each dose. Maintain sodium replacement through sports drink as needed, especially in hot conditions. Avoid large boluses of fuel; instead, rely on small, frequent sips or bites to sustain steady energy and reduce GI distress.
In the final third of the marathon, focus on sustaining energy and minimizing gut discomfort. If tolerance allows, increase carbohydrate intake toward the higher end of your planned range and consider a strategic caffeine boost for mental focus and perceived exertion reduction. Simplify your fueling: opt for liquids and easily digestible gels or chews, especially as core temperature rises and gastric emptying slows. At this stage, fueling execution becomes less about numbers and more about intuition: respond to how your stomach and energy feel, using fluids to maintain rhythm and pace in the final kilometers.
Recovery and Adaptation Nutrition
Maximizing Training Adaptations
Post-workout nutrition extends far beyond glycogen replenishment; it represents your opportunity to optimize the training stimulus and enhance adaptation to the stress you’ve applied. The immediate post-exercise window, spanning 0-30 minutes after completion, demands rapid intervention with 1.0-1.2 grams of carbohydrates per kilogram combined with 0.25-0.3 grams per kilogram of high-quality protein. Include 400-600 milligrams of sodium and 16-24 ounces of fluid per pound of weight loss to address immediate recovery needs.
Extended recovery from 30 minutes to 2 hours post-exercise continues the adaptation process. Maintain carbohydrate intake at 0.5-1.0 grams per kilogram per hour for 4-6 hours following demanding sessions. Include anti-inflammatory foods like tart cherry, berries, and leafy greens to mitigate exercise-induced oxidative stress, while ensuring complete amino acid profiles through varied protein sources.
Sleep and Overnight Recovery
Sleep represents the primary adaptation window where training stress converts to improved performance capacity. Strategic nutrition supports this process through carefully timed interventions. Consuming 20-40 grams of protein before bed provides sustained amino acid availability throughout the overnight fasting period. Include small amounts of carbohydrates (15-30g) if glycogen stores are significantly depleted, but avoid large meals within three hours of bedtime to prevent sleep disruption. Consider Magnesium supplementation in doses of 200-400 milligrams to enhance sleep quality and muscle recovery.
Supplementation for Competitive Endurance Athletes
Evidence-Based Performance Enhancers
- Caffeine remains the most researched and effective performance supplement for endurance athletes. Optimal dosing ranges from 3-6 milligrams per kilogram of body weight, consumed 30-60 minutes before competition. Benefits include reduced perceived exertion, enhanced fat oxidation, and improved focus, particularly valuable during the latter stages of endurance events when concentration typically diminishes.
- Beta-alanine supplementation provides benefits specific to the lactate buffering demands of competitive endurance racing. Daily doses of 3-5 grams for four or more weeks increase muscle carnosine concentrations, improving lactate buffering capacity and reducing fatigue during the final miles when pace typically degrades. Take beta-alanine with meals to minimize the characteristic tingling sensation that occurs with supplementation.
- Sodium bicarbonate offers acute performance benefits through enhanced lactate buffering, though its application requires careful consideration. Doses of 0.2-0.3 grams per kilogram consumed 60-120 minutes pre-race can improve performance, but significant gastrointestinal distress risk demands extensive practice before implementation in competition. Alternatively, there are topical lotions, such as PR Lotion, that can provide similar benefits.
- Beetroot juice and nitrate supplementation have gained considerable research support for endurance performance enhancement. Consuming 400-600 milligrams of nitrates 2-3 hours before competition improves oxygen utilization efficiency and enhances endurance capacity. Begin supplementation 3-7 days before competition for optimal adaptation.
Recovery and Health Supplements
- Omega-3 fatty acid supplementation supports the anti-inflammatory processes essential for adaptation to training stress. Daily intake of 1-3 grams combined EPA and DHA helps manage exercise-induced inflammation while supporting cardiovascular health.
- Vitamin D status significantly impacts performance and recovery, with blood levels above 30 ng/mL (75 nmol/L) optimal for athletic performance.
- Iron deficiency remains common among endurance athletes, particularly females, but supplementation should only follow confirmed deficiency through ferritin testing.
- Protein supplementation supports muscle protein synthesis, tissue repair, and adaptation to training. Aim for ~20–40 g high-quality protein per serving, timed to help you hit a daily total around 1.6–2.2 g/kg bodyweight, with an emphasis on leucine-rich sources to maximize anabolic signaling.
- Creatine monohydrate enhances high-intensity performance and lean mass gains by increasing phosphocreatine stores for rapid ATP regeneration. A consistent daily dose of 3–5 g is sufficient for saturation over time, improving repeated sprint ability, strength, and training quality.
- Collagen supplementation supports connective tissue remodeling, including tendons, ligaments, and cartilage, which are heavily stressed by repeated training. A dose of ~10–15 g taken 30–60 minutes before loading sessions, ideally with vitamin C, may enhance collagen synthesis and joint resilience.
- Fuel (carbohydrate intake) is essential for sustaining training intensity, preserving glycogen, and reducing stress hormone load. For sessions >60–90 minutes, target ~30–60 g carbs/hour (up to ~90 g/hour for longer/harder work using multiple transportable carbs) to support performance and recovery.
- Collagen Shot provides a concentrated, convenient dose of collagen peptides aimed at acute connective-tissue support around training. Use ~10–15 g per shot, timed pre-session with vitamin C to align amino acid availability with mechanical loading for optimal tissue signaling.
- Recovery supplementation helps restore readiness by replenishing glycogen, supporting muscle repair, and reducing excessive soreness. Post-training, prioritize a mix of carbs and protein (roughly 3:1 carbs:protein for endurance-heavy days) plus adequate fluids and electrolytes to accelerate recovery and maintain training consistency.
Troubleshooting Common Fueling Issues
Gastrointestinal Distress During Racing
Prevention strategies for race-day gastrointestinal issues begin weeks before competition. Reduce pre-race fiber intake to less than 10 grams for 48 hours before racing, practice your exact race-day fueling protocol during training sessions, and consider gut-training supplementation with compounds like glutamine and probiotics to support intestinal health. Test different carbohydrate sources and concentrations to identify individual tolerance patterns.
When gastrointestinal distress occurs during competition, immediate management strategies can salvage performance. Dilute fuel sources with additional water to reduce concentration, switch to liquid calories exclusively to ease gastric emptying, reduce intake rate while maintaining consistency, and consider walk breaks to aid digestion and reduce competition between exercise and digestive processes for available blood flow.
Cramping Issues
Electrolyte-related cramping often responds to increased sodium intake, pushing hourly consumption to 600-1,000 milligrams with additional potassium and magnesium supplementation. However, fatigue-related cramping—more common in competitive marathon and Ironman events—requires different interventions. Ensure adequate training volume to prepare muscles for the demands of sustained exercise, practice race-pace efforts with your planned fueling strategy, and consider pacing adjustments if cramping persists despite adequate electrolyte replacement.
Energy Crashes and Bonking
Prevention of energy crashes centers on early and consistent fueling. Start carbohydrate intake earlier in the race, typically by 60-90 minutes rather than waiting until you feel depleted. Increase hourly carbohydrate intake within tolerance limits, use multiple carbohydrate sources to optimize absorption, and practice your carbohydrate loading protocol to ensure maximum glycogen storage before competition.
When energy crashes occur despite preparation, immediate intervention can limit performance decline. Consume 30-40 grams of fast-acting carbohydrates immediately, slow down until blood sugar stabilizes, and resume conservative pacing rather than attempting to make up lost time through increased effort.
Putting It All Together: Your Personalized Protocol
Every competitive endurance athlete requires an individualized approach to nutrition, but the framework for development remains consistent. Begin your assessment phase 8-12 weeks before goal competitions by conducting comprehensive sweat rate testing, determining optimal carbohydrate sources through systematic experimentation, practicing pre-race meal timing to identify individual preferences, and testing supplement protocols under race-like conditions.
The implementation phase, spanning 4-8 weeks before competition, focuses on executing your gut training progression, refining intra-training fueling strategies, practicing race-simulation nutrition during long runs, rides, and tempo efforts, and fine-tuning recovery protocols to support the increased training demands of peak preparation.
The execution phase arrives with race week, where proven protocols replace experimentation. Follow your tested carbohydrate loading routine, adhere to your practiced pre-race nutrition schedule, execute your rehearsed in-race fueling strategy, and trust the preparation you’ve invested months developing.
Post-race analysis completes the cycle and informs future preparation. Document what worked effectively and what requires adjustment, note gastrointestinal tolerance and energy levels throughout the race, plan specific modifications for future competitions, and begin implementing your recovery nutrition protocol to support adaptation to the race stimulus.
The Competitive Edge
In competitive endurance training and racing, nutrition isn’t simply about finishing—it’s about maximizing your genetic potential and extracting every available second from your preparation. The athletes who consistently perform at their highest level understand that fueling represents a trainable system, as responsive to systematic development as VO₂ max or lactate threshold.
Your next personal record isn’t waiting exclusively in your training plan. It exists in your fuel tank, your hydration strategy, your recovery protocol, and your willingness to treat nutrition with the same precision you apply to interval training and workout periodization. The science provides clear direction, the protocols have been proven in both laboratory and competition settings, and the competitive advantage awaits those willing to embrace nutrition as a performance determinant rather than an afterthought.
The question facing every competitive endurance athlete isn’t whether proper fueling will enhance performance—research has definitively answered that question. The only remaining question is how much faster you’re willing to become through systematic application of evidence-based nutrition strategies.
Looking to optimize your nutrition and supplement strategy to fuel your training. Wahoo iss partnered with Momentous—the leader in high-performance human nutrition. Trusted by the U.S. Military, professional sports teams, and Olympic athletes, Momentous develops expertly formulated, rigorously tested supplements designed to meet the demands of serious performance.
Together, we’re delivering not just the tools to train better, but the nutrition to recover, rebuild, and perform for life. Wahooligans get up to 35% off subscription orders – try for yourself today!
