KICKR Climb
Indoor Grade Simulator
€699.99
  • FEATURES
    • Real-time grade changes, up to 20% incline and -10% decline
    • App controlled or manual control with tethered remote
    • Quick connectivity through direct proximity pairing
    • View More
  • SPECS
    • Compatible with 2017 and newer Wahoo KICKR, KICKR CORE, and KICKR SNAP. How to identify your trainer
    • 20% maximum incline
    • -10% minimum decline
  • SETUP
    • Includes adapters for quick release, 12x100, 15x100, and 15x110 Hubs
    • Direct proximity parining via remote
    • Setup Instructions
  • View More
Ride the Revolution
take your ride to new heights
The KICKR CLIMB quickly raises and lowers your bike to match ascents of up to 20% and descents of -10% when paired with the KICKR Smart Trainers.
MAXIMUM GRADE SIMULATION
-10% -5% 0% 5% 10% 15% 20%
MINIMUM GRADE SIMULATION
KICKR CLIMB Features
ELEVATED RIDE FEEL
The KICKR CLIMB indoor grade simulator quickly raises and lowers your bike to match ascents of up to 20% and descents of -10% when paired with the KICKR Smart Trainers. Climbing workouts and virtual courses are now more realistic than ever as the KICKR CLIMB recreates the grade changes in real time.
POWER POSITION
The KICKR CLIMB physically adjusts your bike position to mimic real roads and mountain climbing. This allows you to naturally change position on the bike, engage climbing muscles, and improve pedaling technique while indoors, to become a more efficient and powerful cyclist outdoors.
RIDE ENGAGED
Connect to the most popular online training apps to create a truly immersive ride experience. KICKR CLIMB blends physical grade changes with resistance changes of the KICKR Smart Trainers to take your indoor ride to the next level.
DIRECT PROXIMITY PAIRING
LOCK & UNLOCK MODES
Using the retractable remote, you can set KICKR CLIMB indoor gradient simulator to lock or unlock mode. Unlock mode allows it to automatically react to grade changes from your device or software, whereas Lock mode only responds to manual commands from the remote.
COMPATIBLE WITH MOST BIKES
KICKR CLIMB Specs
TECH SPECS
  • Part Number: WFBKTR5
  • Max Incline: 20%
  • Max Decline: -10%
  • *Exact grade changes dependent on bicycle size, wheel size and trainer type.
  • Compatible Trainers: Wahoo Smart Trainers (KICKR, KICKR CORE, KICKR MOVE, and KICKR SNAP) 2017 Edition and newer
  • Metrics: Current Grade
  • Dimensions: 25.75" H x 5.1" W x 7" L
  • Max User Weight: 250lbs // 114 kg
  • 3rd Party App Compatible: Yes, when paired to a Wahoo smart trainer
WHAT’S IN THE BOX?
  • KICKR CLIMB Unit
  • Power Adapter
  • Adapters for quick release, 12x100, 15x100, and 15x110 Hubs
SUPPORTED DEVICES
The KICKR CLIMB works exclusively with the following Wahoo Smart Trainers:
  • KICKR V6 Released September 2022
  • KICKR V5 Edition released August 2020
  • KICKR 2018 Edition released July 2018
  • KICKR 2017 Edition released August 2017
  • KICKR CORE: Edition released July 2018
  • KICKR SNAP: Edition released July 2017
Please confirm KICKR CLIMB compatibility before purchasing.
bike compatibility
BIKE COMPATIBILITY CHECK
Will my bike fit on the KICKR CLIMB? Find out here.
Start
KICKR Climb
