€599.99
Complete Your Setup
Add accessories, ships with your KICKR ROLLR
KICKR ROLLR only
Total €599.99
  • View More
  • Maximum Power Output: 1500W
  • 10% Simulated Incline
  • View More
  • Some assembly required
  • Compatible with all drivetrains
  • Smooth tread pattern recommended
  • Setup Instructions
KICKR ROLLR Benefits
Stable and Able
Simple Setup
Dual-Roller Design
Optimized Flywheel Technology
Ready. Set. Roll.
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
KICKR ROLLR Features
Controlled Resistance
Quick-Adjust Wheelbase Clamp
Ride with Power
Ecosystem Compatible
Connectivity
Bluetooth
ANT plus ANT+, ANT+ FE-C
1500 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy¹
10%
Maximum Incline
-10%
Maximum Decline
1500 Watts
Maximum Simulated Grade
10%
Minimum Simulated Grade
-10%
Product Weight
50 lb / 23 kg
Drivetrain
N/A
Resistance Type
Electromagnetic
Power Accuracy
Connectivity
Cassette
N/A
Hub Types
N/A
Adapters
N/A
Maximum Rider Weight
250 lb / 113 kg
What’s in the Box
  • AC Power Adapter
  • Owner’s Manual
Supported Devices
Riding on KICKR ROLLR
Bike Compatibility
Start
Your KICKR Ride Companion
    FAQ
    Compare smart trainers
    €849.99
    Accuracy
    Accuracy +/- 1%
    Wireless Firmware Updates
    Max Power Wattage 2200 Watts
    Simulated Gradient
    Zwift Cog & Click
    Zwift Cog & Click Compatible
    KICKR CLIMB Compatible
    ERG Easy Ramp ERG Easy Ramp
    RaceMode
    RaceMode
    KICKR Core 2
    KICKR CORE 2
    €549.99
    Accuracy
    Accuracy +/- 2%
    Max Power Wattage 1800 Watts
    Simulated Gradient
    Zwift Cog & Click
    RaceMode
    RaceMode
    €599.99
    Accuracy
    *onboard power available
    Max Power Wattage 1500 Watts
    Simulated Gradient
    Spares & compatible add-ons for the KICKR ROLLR.
    2 items
    Smart Bike Roller Trainer
