SPEEDPLAY ZERO
Stainless Steel Pedals
€199.99
Built to take on anything, the SPEEDPLAY ZERO road pedal is uniquely qualified to withstand the demands of everything from all-out racing to the epic grind of a double-century. The stainless steel dual-sided bike pedal and integrated cleat system offer peak power transfer and exceptional durability. The customized fit and dual-sided entry will allow you to crank on the pedals in confidence and comfort.
Cleats are included.
Complete Your Setup
Add accessories to your order — ships together
Included
SPEEDPLAY ZERO
€199.99
Your setup
SPEEDPLAY ZERO only
Total
€199.99
Includes SPEEDPLAY ZERO
SPEEDPLAY ZERO Features
Dual-Sided Entry
SPEEDPLAY ZERO pedals' symmetrical design allows for effortless dual-sided entry. No more fumbling—clip in quickly and ride off with confidence.
Enhanced Walkability
Integrated Profile
ZERO pedals and Standard Tension Cleat create a streamlined, secure connection, improving power transfer and aerodynamics.
Unbeatable Stack Height
3-Axis Cleat Adjustability
Optimized Biomechanics
Rotational Free Float
Superior Cornering Clearance
Exceptional Durability
Stainless steel build and sealed bearings offer long-lasting durability with minimal maintenance for even the most demanding cyclists.
ZERO pedals include a set of Standard Tension Cleats and cleat surrounds for an aerodynamic and walkable system.
Easy Tension Cleat Compatible
What's Included?
  • Left and Right Pedals
  • Cleat Assembly
  • Screw Packet
  • Quick Start Guide
Tech Specs
  • Part Number: WFPRZ1S53 - 53mm
    WFPRZ1S56 - 56mm
    WFPRZ1S59 - 59mm
    WFPRZ1S65 - 65mm
  • Shipping Weight: 1.22lb
  • Country of Origin: Vietnam
  • Weight: 222g per pair
  • Q Factor: 53mm, 56mm, 59mm, or 65mm
  • Body Material: Grivory
  • Cornering Clearance: 39°
SPEEDPLAY ZERO
