€79.99
TICKR FIT heart rate armband uses optical heart rate technology to provide accurate heart rate and calorie burn data in the most comfortable form factor yet! Equipped with Bluetooth and ANT+ technology to seamlessly pair with fitness apps, smartphones, and GPS bike computers and watches. Worn on the forearm, the TICKR FIT heart rate monitor comes with an adjustable band that is designed for your most grueling workouts including running, cycling, fitness classes, and more. TICKR FIT has water-resistant technology and a rechargeable battery that lasts up to 30 hours.
  • Optical heart rate technology for accurate heart rate and calorie data
  • Up to 30 hours of battery life on a charge
  • Performance band designed to sit comfortably and stay secure through intense activity
  • LED lights confirm the connection to your phone, watch or bike computer
  • Syncs with Apple Watch, Strava, Peloton, adidas Running, Nike Run Club and the Wahoo ecosystem
  • Type: optical armband monitor
  • Weight: 0.7 oz / 19.8 g with strap
  • Battery: rechargeable lithium-ion
  • Battery Life: up to 30 hours
  • Strap Sizes: small 10 x 1 in (260 x 25.4 mm), large 15 x 1 in (375 x 25.4 mm)
  • Water Rating: IPX7
  • Connectivity: Bluetooth and ANT+, one Bluetooth connection
  • Wear it on the forearm or upper arm, snug enough that the sensor stays flat against the skin
  • Two band sizes included - fit the one that holds without pinching
  • Pair from the Wahoo App, a GPS watch or a bike computer - the LEDs confirm the connection
  • Band is handwash only; remove the pod before washing
Meet TICKR FIT
TICKR Fit heart rate monitor with arm band
Connect with Confidence
TICKR FIT connects to smartphones, GPS watches & bike computers, and it verifies the connection by using convenient LED lights.
Ultimate Precision
TICKR FIT uses trusted and time-tested optical heart rate technology to give you accurate heart rate and calories burned data.
Powered to Perform
TICKR FIT’s rechargeable battery is sure to power you through any workout. With up to 30 hours of battery life, you can be confident that TICKR FIT will be ready to go when you are.
Comfortable and Secure
Made from advanced performance materials, TICKR FIT’s band is designed to fit comfortably around your arm, yet fit securely during intense activity.
TICKR FIT HEART RATE Features
Connect with confidence
TRACKR HRM Data
Comfortable and secure
TRACKR's LED indicator
Connected Training
Protected from the Elements
TICKR FIT HEART RATE is your perfect companion for rainy rides or a sweaty run. Rated IPX7, you can push your limits without worrying about the elements.
What’s Included
TICKR Fit Unit
TICKR FIT Unit
TICKR Fit Strap
Small and Large Arm Straps
TICKR Fit Charger
Battery Charger
Tech Specs
  • Battery Life: Over 30 Active Hours
  • Sweatproof: Yes (Hand washable Strap)
  • Water Rating: IPX7 (waterproof up to 5 feet)
  • Strap Length: Small 10" x 1" (260mm x 25.4mm) and Large 15" x 1" (375mm x 25.4mm)
  • Connectivity: ANT+ and a single Bluetooth connection
  • On/Off Button
  • Not compatible with chest straps
Compare heart rate monitors
Both read heart rate the same way to your apps and head unit. The difference is where you wear the sensor and how long it runs between charges.
TRACKR Heart Rate monitor with chest strap
TRACKR Heart Rate
  • Weight: 1.4oz 39g
  • Water: IPX7
TICKR FIT heart rate monitor with armband
TICKR FIT
  • Weight: 0.7oz 19.8g
  • Life: Up to 30 hours
  • Length: Small: 10" x 1"
    Large: 15" x 1"
    Small: 260mm x 25.4mm
    Large: 375mm x 25.4mm
  • Water: IPX7
Which one should I buy?
Spares & compatible add-ons for the TICKR Fit Armband.
1 item
TICKR Fit Armband
Heart Rate Monitor
