KICKR BIKE Smart Bike
    €3,799.99
    The all new KICKR BIKE Smart Bike offers unprecedented innovations such as integrated grade changes, customizable gearing, and simulated shifting to create the most powerful, personalized, and realistic indoor cycling and training experience.
    • FEATURES
      • Real-time physical grade changes for immersive and realistic rides.
      • Accurate power measurement of +/- 1% with up to 2500W of resistance.
      • Virtually silent operation
      • NEW - Direct Connect and WiFi Connectivity
      • NEW - Odometer tracks total trainer mileage
      • Race Mode uses Wi-Fi or Direct Connect capability to broadcast power up to 10x faster for a competitive advantage at critical race stages. Learn more.
    • SPECS
      • Power Accuracy: +/- 1%
      • Maximum Power Output: 2500W
    • SETUP
    RECOMMENDED ADD-ONS
    KICKR Headwind Bluetooth Fan
    KICKR HEADWIND BLUETOOTH FAN
    €279.99
    This smart fan adjusts to match your riding speed or heart rate, or select manual settings.
    Wahoo SPEEDPLAY ZERO dual-sided stainless pedals.
    SPEEDPLAY ZERO PEDALS
    €199.99
    Stainless steel dual-sided bike pedal and cleat system offer a customized fit for peak power transfer.
    Wahoo KICKR Trainer FloorMat
    KICKR TRAINER FLOORMAT
    €79.99
    RIDE THE REVOLUTION
    KICKR BIKE smart bike trainer is compatible with KICKR Trainer Accessories, including the KICKR DESK and KICKR HEADWIND Smart Fan, allowing you to build the ideal setup to make your smart bike experience next level immersive.
    KICKR BIKE Features
    Unmatched ride feel
    KICKR BIKE combines controlled resistance with built-in grade simulation to replicate the sensation and body position of riding outdoors – including downhill simulation that allows you to maintain speed on virtual descents.
    Reality Shift
    True fit
    Guided by an intuitive set-up app, KICKR BIKE's 5-point adjustment system lets you easily adjust frame, setback and reach dimensions to optimize overall bike fit for comfort and performance.
    RIDE REAL.
    This smart bike combines KICKR’s legendary ride feel with cutting-edge innovations like integrated grade simulation to create an indoor cycling experience that blurs the line between virtual and reality.
    MAX GRADE SIMULATION
    10% 12% 16% 20%
    MIN GRADE SIMULATION
    10% 12% 15% 20%
    MAX POWER (WATTS)
    1500w 1800w 2200w 2500w
    KICKR BIKE FEATURES
    REALISTIC RIDE FEEL
    KICKR BIKE Smart Bike combines KICKR’s legendary resistance and grade simulation technologies to replicate the sensation of riding outdoors – including downhill simulation that allows you to maintain speed on virtual descents.
    REAL-TIME PHYSICAL GRADE CHANGES
    FIVE POINT ADJUSTABLE FIT
    Adjust the fit of your smart bike to match your outdoor bike's geometry across 5 points - stack, reach, setback, saddle height, and frame height.
    PROGRAMMABLE VIRTUAL SHIFTING
    Customize the KICKR BIKE shifting controls to match shifters from the leading manufacturers - SRAM, Shimano, and Campagnolo.
    PROGRAMMABLE GEARING
    SEAMLESS CONNECTIVITY
    Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR BIKE smart bike pairs to most devices and applications so you have the most control over your training and ride data.
    KICKR BIKE SPECS
    TECH SPECS
    • Maximum Power Output: 2500 Watts
    • Product Weight: 93 lb / 42 kg
    • Drivetrain: Belt Drive
    • Resistance Type: Electromagnetic and enhanced motor
    • Power Accuracy: +/-1%
    • Crank Arm Lengths (mm): 165, 167.5, 170, 172.5, and 175
    • Rider Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
    WHAT’S IN THE BOX?
    • KICKR BIKE smart bike
    • AC Power Adapter
    • Handlebar Assembly
    • Does not include pedals
    SUPPORTED DEVICES
