KICKR MOVE Smart Trainer
€1,299.99
With the introduction of fore-aft motion, the KICKR MOVE bike trainer allows your bike to move naturally for a more comfortable and realistic riding experience than ever before.
  • FEATURES
    • NEW - 8" (20cm) fore-aft motion responds to changes in riding tempo
    • KICKR MOVE base allows for additional side to side movement as well as the adjustable AXIS feet
    • Virtually silent operation
  • SPECS
    • Power Accuracy: +/- 1%
    • Maximum Power Output: 2200W
    • Minimum Simulated Grade: -10% (-8% with CLIMB)
  • SETUP
Real you can feel
KICKR MOVE delivers an entirely new dimension of ride feel. With built-in, dual axis movement and KICKR’s legendary flywheel technology, KICKR MOVE allows your bike to travel freely when powering through indoor rides and workouts. The result is a more engaging, more comfortable and more realistic riding experience than ever before.
KICKR MOVE Benefits
A new reality
KICKR MOVE integrates multiple dimensions of movement into a wheel-off trainer - combining the ride feel that has made KICKR the Choice of Champions with true fore-to-aft and side-to-side movement.
Ultimate comfort
This smart bike trainer provides next level comfort to your indoor rides; the movement unleashed by its dual-axis motion reduces fatigue and improves overall efficiency, allowing you to train longer and harder than ever before.
Next level experience
KICKR MOVE moves with you. This freedom mirrors what you feel outdoors, bringing next-level realism, fun and engagement to structured workouts, virtual races and indoor rides.
KICKR quality guaranteed
Built to exacting standards, KICKR MOVE is incredibly stable, quietly powerful, precisely accurate and completely connected.
KICKR Smart Trainer
Next Level Experience
From pushing out of the saddle on an explosive attack, to finding your rhythm during a tough endurance effort, when you move, KICKR MOVE moves with you. This freedom mirrors what you feel outdoors, bringing next-level realism and comfort to your indoor rides or lock in your position for focused efforts.
MAX GRADE SIMULATION
10% 12% 16% 20%
MAX POWER (WATTS)
1500w 1800w 2200w
KICKR MOVE Features
Ultimate Comfort
KICKR MOVE provides next-level comfort to your indoor cycling rides; the movement unleashed by its fore-aft motion reduces fatigue and improves overall efficiency, allowing you to train longer and harder than ever before.
Lock-Out Option
When you want stability or a dialed-in position, KICKR MOVE features an option to prevent fore-aft movement and lock KICKR MOVE into place.
Erg Easy Ramp
Need to pause the workout for any reason? ERG Easy Ramp™ gets you back into the effort gradually instead of requiring a leg-busting effort to hit your power numbers.
Professional Grade Durability
Seamless Connectivity
Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR indoor bike trainers pair to most devices and applications so you have the most control over your training and ride data.
No limits training with Wahoo X
All Wahoo smart bike trainers and smart bikes come with a trial to Wahoo X, giving you access to SYSTM, a comprehensive collection of structured workouts and training plans, tailored towards your fitness objectives.
KICKR MOVE Specs
Tech Specs
  • Product Weight: 64 lb / 29 kg
  • Drivetrain: Belt Drive
  • Power Accuracy: +/-1%
  • Connectivity: Direct Connect, ANT+, ANT+ FE-C, WiFi and Bluetooth
  • Cassette: Includes choice of 11-speed with 11-28 ratio or Zwift Cog
What's in the box?
  • KICKR MOVE
  • AC Power Adapter
  • Quick Release Skewer
  • Disc Brake Caliper Spacer
  • 1.8mm Cassette Spacer
  • Reversible hub spacer for 130mm and 135mm
  • AXIS Stiff and Easy Feet
Supported Devices
  • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
  • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
BIKE COMPATIBILITY
Bike Compatibility Check
Start
