Certified Reconditioned - KICKR BIKE SHIFT
€2,299.99
This is a refurbished KICKR BIKE that carries the full two year warranty. Our team of Wahooligans have completely tested the product and brought it up to factory specifications. Cosmetically, there might be some scratches or nicks
  • FEATURES
    • Virtually silent operation
  • SPECS
    • Power Accuracy: +/- 1%
    • Maximum Power Output: 2200W
  • SETUP
True Fit
Guided by an intuitive set-up app, KICKR BIKE SHIFT's 5-point adjustment system lets you easily adjust frame, setback and reach dimensions to optimize overall bike fit for comfort and performance.
KICKR BIKE SHIFT Features
Real-time response
KICKR BIKE SHIFT features a brake and belt drivetrain system that delivers responsive resistance to grade and power changes.
Reality Shift
True fit
Your ride. Inside.
MAX GRADE SIMULATION
10% 12% 16% 20%
MIN GRADE SIMULATION
10% 12% 15% 20%
MAX POWER (WATTS)
1500w 1800w 2200w 2500w
Real-Time Response
KICKR BIKE SHIFT's innovative brake and belt drivetrain system delivers lightning fast resistance response to grade and power changes.
Five Points of Adjustable Fit
Adjust the fit of your smart bike to match your outdoor bike's geometry across 5 points - stack, reach, setback, saddle height, and frame height.
Programmable Virtual Shifting
Customize the KICKR BIKE SHIFT controls to match shifters from the leading manufacturers - SRAM, Shimano, and Campagnolo.
Programmable Gearing
No Limits training with Wahoo X
KICKR BIKE Shift Specs
Tech Specs
  • Product Weight: 79 lb / 36 kg
  • Drivetrain: Belt Drive
  • Resistance Type: Electronic Brake
  • Power Accuracy: +/-1%
  • Crank Arm Lengths (mm): 165, 167.5, 170, 172.5, and 175
  • Rider Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
What's in the box?
  • KICKR BIKE SHIFT smart bike
  • AC Power Adapter
  • Handlebar Assembly
  • Does not include pedals
SUPPORTED DEVICES
  • MacOS: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
  • Windows PC: Wifi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
