Smart Trainers. Smarter Training.
KICKR Smart Bike Trainers
Your Ride. Your Choice.
Bring Your Ride Inside
  • Real Road Feel
    Real Road Feel
  • Fully Connected
    Fully Connected
  • Easy To Store
    Easy To Store
    Starting at €549.99
    Wheel-Off
    Convenience
    Power accuracy
    Virtually Silent
    Road Feel
    Wheel-on
    Convenience
    Power accuracy
    Virtually Silent
    Road Feel
    KICKR Move
    KICKR MOVE
    €1,299.99
    Fore & Aft Movement Fore & Aft Movement
    Accuracy
    Accuracy +/- 1%
    Wireless Firmware Updates
    Max Power Wattage 2200 Watts
    Simulated Gradient
    Zwift Cog & Click
    Zwift Cog & Click Compatible
    KICKR CLIMB Compatible with accessory (not included)
    ERG Easy Ramp ERG Easy Ramp
    RaceMode
    RaceMode
    €999.99
    Accuracy
    Accuracy +/- 1%
    Simulated Gradient
    Zwift Cog & Click
    RaceMode
    RaceMode
    KICKR Core 2
    KICKR Core 2
    €549.99
    Accuracy
    Accuracy +/- 2%
    Max Power Wattage 1800 Watts
    Simulated Gradient
    Zwift Cog & Click
    RaceMode
    RaceMode
    €599.99
    Accuracy
    *onboard power available
    Max Power Wattage 1500 Watts
    Simulated Gradient
    Your KICKR Ride Companion
      FAQ
      Bike Compatibility
      KICKR trainers are compatible with most modern road, mountain, and gravel bikes. Compatibility depends on your bike's drivetrain and axle configuration. Check our online compatibility guide or contact support with your bike's details for a definitive answer.
      KICKR trainers include adapters for common axle standards. Some bikes with unique configurations may need additional adapters. Consult our compatibility guide or support team to determine if you need extra adapters for your bike.
      Cassette Compatibility
      KICKR COREs are offered with a variety of cassettes. KICKR and KICKR MOVE are offered with 11 speed cassettes. KICKR direct drive trainers are compatible with 8-12 speed cassettes from major manufacturers using the Shimano HG freehub standard. Some 12-speed systems may require a specific freehub body. Check product specifications for details.
      Usually, yes. If your cassette is compatible with the KICKR's freehub body, you can transfer it. Many users prefer a dedicated cassette for their KICKR to avoid frequent swapping.
      Zwift Compatibility
      Yes, all KICKR trainers work with Zwift, providing power data, resistance control, and gradient simulation.
      General Product Information
      KICKR models differ in power output, accuracy, connectivity options (e.g., Wi-Fi, Direct Connect), and virtual cycling feature compatibility. Higher-end models typically offer better performance, more features, and wider compatibility with bikes and cycling platforms.
      Wi-Fi and Direct Connect are available on KICKR v6 and KICKR MOVE models. Check specific model specifications or contact support for feature confirmation.
      Setup and Accessories
      You'll need the KICKR trainer, a compatible bike, matching cassette (if not included), any necessary adapters, basic tools for cassette installation, and a device for the Wahoo app setup. Consult the user manual for detailed instructions.
      KICKR trainers include adapters for most common axle standards. Bikes with unique configurations may need additional adapters. Check our compatibility guide or contact support if unsure about your bike's requirements.
      Wheel-on trainers (like KICKR ROLLR) use your bike's rear wheel against a resistance roller. They're more affordable and easier to set up. Direct drive trainers (like KICKR CORE and KICKR) attach directly to your bike without the rear wheel. They offer a more realistic feel, quieter operation, and typically more accurate power measurements.
      Choose wheel-on for budget-friendliness and easy switching between indoor/outdoor riding. Opt for direct drive if you want the most realistic feel, quietest operation, and highest accuracy. Consider your budget, space, and training goals when deciding.
      While not required, a trainer-specific tire is recommended for wheel-on KICKR models. These tires better withstand the heat and friction of indoor training, reducing wear and noise.
      Yes, most KICKR trainers accommodate various bike types with the right adapters. Check the specific model's compatibility information and included or available adapters for your bike type.
      Direct drive KICKR trainers generally offer higher power measurement accuracy than wheel-on models, as they eliminate variables like tire pressure and roller slippage. Both types provide reliable data for effective training.
      Calibration frequency varies. Wheel-on KICKR trainers should be manually calibrated before each ride. Current direct drive models offer auto-calibration. Follow the Wahoo app instructions for your specific model.
